RE: Roco SBB coaches - adding 3 rail lighting
#1 von LongHairedDavid , 20.11.2019 13:21
Hi everyone
I have three Roco SBB coaches. (see picture). The one shown has a slider and outer rail pickup for interior lighting. I have installed a keep alive and replaced the two bulbs with an LED strip. It works very well. I have carried wires from that coach across to the other two coaches but now they are permanently attached and the wires are giving me some issues going round my R1 and R2 curves (I have a Marklin layout)>
I have tried fitting some micro plugs and sockets but the wires are still a bit stiff. I would like to fit sliders, etc. to the other two coaches. Can anyone tell me where I could find some sliders etc. for these two coaches?
Long Haired David
AKA David Pennington
Maerklin newby so lots to learn
LongHairedDavid
LongHairedDavid
Registriert am: 30.05.2019
#2 von morterti , 20.11.2019 13:45
Hello David,
There are several sliders you can use, i think the one you used was a Märklin one. You can buy several sliders at the Märklin Website, here‘s one:
https://www.maerklinshop.de/maerklin/spu...leifer-2-stueck
You also find lots of other things there that could be useful.
I however would recommend you another solution: Instead of using wires you can use electric couplers that make sure that there is a power supply without having to connect the coaches permanently.
Here‘s one from Märklin:
https://www.maerklinshop.de/en/maerklin/...ucting-couplers
Or one from Viessmann:
https://viessmann-modell.com/sortiment/e...-2-polig-1-paar
I hope I colud help you!
Mein Umstieg auf DC und meine Deutsch-/Österreichische Teppichbahn!
viewtopic.php?f=168&t=169932
morterti
morterti
Registriert am: 22.06.2017
Gleise Märklin/Trix C
Steuerung CS2
#3 von Heinzi , 20.11.2019 17:30
Hello David
As morterti said, i would also not recomend sliders and Rail pick up's on each coaches.
The rolling resistance would increase dramatically, also the noise level.
Depending on the locomotive you would not be able to connect more coaches.
I would recommend coupling device with 2 pools (+ and -) because of the rail pick up's.
Is it possible to use the coupling devices (pluggable) as proposed by morterti? If not it will be difficult.
Gruss Heinzi
CS1R / ControlGui
Heinzi
Registriert am: 26.04.2006
#4 von LongHairedDavid , 21.11.2019 11:06
I have moved to the idea of conductive couples as these coaches all have NEM sockets. However, they will both need outside rail pickups as the coupler only transmits the puko.
Long Haired David
LongHairedDavid
LongHairedDavid
#5 von LongHairedDavid , 22.11.2019 19:11
I have ordered some ESU conductive couplers as these pass both wires meaning I need only one slider and outside rail pickup.
I will report back as and when they arrive.
Long Haired David
LongHairedDavid
LongHairedDavid
