RE: SELCUK-EPHESUS EIN ANTIC PLAN
#26 von abdusta ( gelöscht ) , 27.02.2009 10:29
Good days
I continue with weathering and aging - adding stairs and balcony with evergreen
regards
a.usta
abdusta
#27 von Joeys Teppichbahn , 27.02.2009 10:32
Hello,
good work. Its verry great. good photos.
Jo
LG, Joey ;)
Mein Thread - Joeys Teppichbahn - im Stummiforum
Joeys Teppichbahn
Registriert am: 12.02.2009
Gleise RocoLine m. Bettung
Steuerung z21
#28 von abdusta ( gelöscht ) , 02.03.2009 10:13
I use Faller control table
prepared the colored led lights bind them under the table
inorder to get collective light I use very short fiberoptic cable
I continue to furnish.
regards
a.usta
abdusta
#29 von malaz ( gelöscht ) , 02.03.2009 13:30
Wow! That's fantastic! Great work!!
malaz
#30 von UlrichRöcher ( gelöscht ) , 03.03.2009 08:59
Hi abdusta,
the broken windows!
How did you do that?
Greetings
UlrichRöcher
#31 von abdusta ( gelöscht ) , 03.03.2009 11:02
Gutentag Ulrich
Broken windows did during moulding
with hand made within seconds just before drying the rezin
this technique could not applicable for ready kits.
regards
a.usta
abdusta
#32 von abdusta ( gelöscht ) , 19.03.2009 12:36
SHANTY
Today I present my Tipic Turkish shanty hand works.
This is a mould works for a modular rezin production
I use for columns evergreen sticks
These moduler parts could be easily modified for obtain
2-3 flats or more wider-narrow buildings
You see construction iron sprout on roof.
20 years ago people built and left the roof as seen,
till municipal elections and trying to complete unlicencied constructon.
I found a photo of mr.Markus Göttert very famous German gent, Turkish railways lover with his deeply photo archive for 20-10 years ago.
This photo has been taken summer of 1989 in Selcuk station.
The fllwgs pictures narrating itself how to change rezin to shanty.
regards
A.Usta
abdusta
#33 von Jumbo , 19.03.2009 21:35
Hello abdusta,
wow wonderful great work. I feel like that I`m in holiday. It`s everytime a pleasure for me to see your perfect buildings.
greetings
jumbo
Jumbo
Registriert am: 09.08.2005
Gleise C und M
Spurweite H0, 1
Steuerung Analog und Digital
#34 von Andi , 19.03.2009 21:40
Hello abdusta,
once again, I'm highly impressed.
Wonderful work
Andi
Registriert am: 21.05.2005
Steuerung CS 2 / CS 3
#35 von abdusta ( gelöscht ) , 27.03.2009 12:17
Good days
Most of kits what I need not selling in box.
Naturally I use sometimes ready objects such as evergreen sticks and
faller remain parts especially doors-windows etc.
For example for Selcuk project one of the biggest building
just next to station is TABACCO DEPOT
for modeling this building I prepared a master mould of 1/3 rd part of the building marked yellow lines. after more study on the mould
for details and putty. I copied the pieces in silicone mould.
The connection points camouflaged by black pipes
On the other hand by this master mould could built different types
of stone building -depots.
I add another bigger shanty house works you see how I use the
mould of first shanty house in different way
I paint with waterbased spray tamiya colors white and bit grey
for the roof orange and bit brown.
These based colors after 24 hours drying will hold the guaj colors
for stone gay and bricks red and finally with oil based paints will
complete the effects and weathering.
regards
A.Usta
[img]
abdusta
#36 von grove den , 27.03.2009 15:49
Again AWESOME Abdusta!!
BTW you are lucky they used large bricks/stones fot this building!
Anyhowe it is still , again, goin to be a masterpiece on your layout!
terrific choosen ( tones of)colors
Jos
ps: watching the pictures from your layout will give me always a feeling of bein on vacatiion all the time.....
Modellbäume natürlich!
mbbgroveden.com
grove den
Registriert am: 08.12.2007
#37 von Stahlbahn ( gelöscht ) , 27.03.2009 18:20
Hello Abd, this is really great work! I admire those who can make their own moulds. Regarding the Tobacco depot, aren't you worried that using the same brick pattern three times isn't easily spotted?
Looking forward to meet you and Erkut in Dortmund,
Stahlbahn
#38 von abdusta ( gelöscht ) , 31.03.2009 11:40
Hello Frank You are right for use same moulds,with paints and effects
I tried to settle said question
For example below pictures
If carefully checked walls of 1st shanty and this is same moulds
we also looking forward to meet you in Dortmund.
regards
a.usta
abdusta
#39 von AlwinS ( gelöscht ) , 31.03.2009 13:47
WOOOOOWW!
AlwinS
#40 von abdusta ( gelöscht ) , 07.04.2009 12:34
In Turkey, very often meet stone walls sides of the railways in stations
also same built in Selcuk station
for my project I try to copy similiar wall in the picture
I did resin works and use weinert Brüstung painted to white and blue
regards
a.usta
abdusta
#41 von AlwinS ( gelöscht ) , 07.04.2009 12:48
Real great,
I saw such modells not often before
Great
Alwin
AlwinS
#42 von abdusta ( gelöscht ) , 07.04.2009 13:26
Good days
I attached 2 panoramic pictures from my selcuk layout
a while ago ballasting works
regards
a.usta
abdusta
#43 von Der Krümel , 07.04.2009 14:59
Wow!
Again: Great work!
Is there (or will there be) a 1/87-abdusta anywhere?
Hendrik
Der Krümel
Registriert am: 27.04.2005
Steuerung Tams MC
#44 von abdusta ( gelöscht ) , 20.04.2009 10:36
continue worked with weinert added hand product locker
will continue with more grass,sand etc
regards
a.usta
abdusta
#45 von grove den , 20.04.2009 23:17
It is always great, a lot of fun, and most of all: amazing : the self made scenery/things you show us overhere in your pictures each time!
Jos
mbbgroveden.com
grove den
#46 von abdusta ( gelöscht ) , 07.05.2009 09:35
Hello
There is no original model production for Turkish Locos.
so you have to modify the locos with limted photos found.
I cut-add-paste-paint and make this steam loco 55043 used in Selcuk
station
It was modified from br57
regards
a.usta
abdusta
#47 von abdusta ( gelöscht ) , 11.05.2009 12:09
Good days
I was in Selcuk this weekend for smelling,feel,observation and most important to collect historical evidence of my working period 1980-1985,I talked with many retired railway workers in Selcuk.
I know in many countries it is prohibited to enter the Cab of Trains
However if you are a modeller and living in Turkey all doors opening for you including bonus to drive the train for a short time.
First visited selcuk depot to compare with model
At 11.30 hrs train arrived in time,we crew on board immediately.
signalisation by human as same in historical years.
we are on the way of AYDIN
continue..
regards
a.usta
abdusta
#48 von abdusta ( gelöscht ) , 18.05.2009 09:42
Hello zusammen
There was very famous signal house in Izmir which cleared 2 years ago.
I did similiar to use in Selcuk Project
Preiser crew uniforms painted exactly Turkish train officiers summer color
Base gips works upper side resin works Ladder from Bavaria
regards
a.usta
abdusta
#49 von grove den , 18.05.2009 13:17
Masterpiece!
You did it agian!
great pictures too!
Jos
mbbgroveden.com
grove den
#50 von Andi , 18.05.2009 18:08
Brilliant work
Andi
