Marklin BR 50 von 29500 Ersatzteil Kabin!!
daniel_black
Kanada
Beitrag von daniel_black »
Jeder hat eine Ersatzteil-Kabine für die BR 50 aus dem Märklin-Set 29500
anyone has this spare part for the cabin of the BR 50 marklin set 29500?
Danny
DB 94 534
Re: Marklin BR 50 von 29500 Ersatzteil Kabin!!
Beitrag von DB 94 534 »
Hello,
which part are you looking for? Maybe you should try to ask in the "Suche" area, there will more people read your inquiry.
Regards
daniel_black
Kanada
The locomotive kabin
daniel_black
Kanada
Where is the Suche area?
volkerS
Steuerung: MS1/ MS2 /analog
Beitrag von volkerS »
Hallo Daniel,
on Startpage scroll down to "Suchen, Kleinanzeigen und Schnäppchen-Hinweise ". Open and you see as second Folder "Suche".
Parts you can use for the Br50 (29500) are (prices from 2011):
Märklin part No. 232780 Windleitblech rechts 1,99 €
Märklin part No. 232790 Windleitblech links 1,99 €
Märklin part No. 222816 Treppe zur Rauchkammer 0,79 €
Märklin part No. 218944 Rauchkammertür 9,99 €
Märklin part No. 210085 Kesselumlauf 19,95 €
Märklin part No. 218945 Führerhaus 7,99 €
If only want the cabin housing of the coal car:
Märklin part No. 218952 Kabinentenderaufbau 24,95 €
Here you see the result: https://www.stummiforum.de/viewtopic.ph ... 85#p621963
Ulrich A.
Steuerung: CS1 mit ESU-update, 2 MS1
Beitrag von Ulrich A. »
daniel_black hat geschrieben:
Di 3. Dez 2019, 01:54
It is possible that you are not unlocked for the "Search" section. You must have written a certain number of posts and you have to be a member for a while to be automatically unlocked.
Grüsse aus dem Sauerland
DB 94 534
Hello,
if he isn't unlocked, he can read but not write.
Regards
Zurück zu „Reparaturen“
